Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro > F-Bodies (Camaro and Firebird) > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 04-25-2008, 11:27 AM   #1
Prix87
Prix87 Normal reputation
oil leakage
Hello fellas,
Driving 84 camaro, 2.8 v6, 5 speed manual trans. Now leaking oil. I'm told it may be the main rear seal but i'm not looking to drop the trans if i don't have to, to replace the gasket. However i'm told it could be the speedometer oil seal. The speedometer needle does bounce around when cruising. Any input would be appreciated
Prix87 is offline   Reply With Quote
Old 04-26-2008, 02:16 PM   #2
72chevelleOhio
72chevelleOhio Normal reputation
Re: oil leakage
I had a 2.8 that I couldn't find the leak on, it wound up being a valve cover gasket. It was bad in the back, oil ran down and wind blows it everywhere. I would triple check everything before pulling the tranny...
72chevelleOhio is offline   Reply With Quote
Old 04-29-2008, 02:19 AM   #3
Prix87
Re: oil leakage
funny you say that. started lookn' over the motor and saw significant amount of oil all over the exhaust manifold and block... basically everything under the valve covers. So decided to replace the gaskets. That, on the 2.8 requires taking upper/lower plenum, fuel rail n' injectors out to get access to cover bolts. The valve cover bolts were terribly loose along with a rotted quark gasket....
Bookmarks
Google
Web AF
