Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 04-24-2008, 10:21 PM   #1
bmay
bmay Normal reputation
97 Astro ... Replace Front Shocks. Hmmmmmmm?
This turns out to be a minor nightmare! No way to hold shock stem AND loosen/remove upper stem nut. The stem just spins.
Gonna have to take this "simple" job to a shop? Ideas welcome.
bmay is offline   Reply With Quote
Old 04-25-2008, 07:57 AM   #2
brcidd
brcidd's Avatar
brcidd Normal reputation
Re: 97 Astro ... Replace Front Shocks. Hmmmmmmm?
A good pair of vice grips will do it--- or you can cut the old ones out as most shops do.....
Automotive A/C Engineer with:
'95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone- blown head gasket
'92 Chevy Lumina Van 3.8L 264k miles
'86 GMC S-15 - 2.8L 154k miles
'86 Buick Park Ave 3.8L 199k miles- my daily driver
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles- my high school car!!
All but the Camaro and Firebird are white....
brcidd is offline   Reply With Quote
Old 04-25-2008, 11:32 AM   #3
bmay
I can't vice grip the stem AND put a wrench (or socket) on the nut at the same place (on top of stem). I will take your advice however. I found I can JUST reach the shock stem with the vice grips through the coil springs. Hope this works.
Old 04-25-2008, 11:57 AM   #4
brcidd
brcidd's Avatar
That's how I do it- through the coils-- you will twist off the top of stem about half the time...........so what it comes out easier.....that way..
Old 04-25-2008, 12:30 PM   #5
bmay
Thx for the Info. I will do the job this weekend and letcha know if I still have fingers.
Old 04-25-2008, 06:00 PM   #6
CD Smalley
CD Smalley Normal reputation
Deep well socket on the nut and a long extension. Rock it back and forth until the stem breaks.
CD Smalley
1991 W41 #142
1995 Astro
1989 Caprice 9C1
1997 C1500
1977-90 GM B-Body email list Owner @ yahoogroups.com
In the recovery room: b-body.org...
CD Smalley is offline   Reply With Quote
Old 04-25-2008, 08:16 PM   #7
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
I agree! 10 seconds (maximum) and it's off! No torch, no special tools, no muss, no fuss.
old_master is offline   Reply With Quote
Old 04-25-2008, 09:53 PM   #8
bmay
Even better! Snap, Crackle and POP!
Thanks all. Saves my day!
Old 05-20-2008, 10:45 PM   #9
SAFARI_MAN
SAFARI_MAN Normal reputation
Loose the lower bolts first. Pull the shock from the bottom side toward the floor. That will give you more clearance to hold the stem through the coils with a vicegrip, then with a deep socket, remove the stem nut. When installing, do the upper side first, hold the stem gently with the vicegrip, then do the lower 2 bolts last. I will apply some hi loctite on these bolts.
Hope it helps
Safari_Man
SAFARI_MAN is offline   Reply With Quote
Old 05-20-2008, 11:52 PM   #10
bmay
TY Safari Man. As suggested, I used a deep socket and an extension and rocked the stem till it broke off. ALL other methods failed to work. Tried 'em all over 3 Sunday afternoons. Bummer, but they are now installed. Thanks for suggesting loc-tite. Great idea!
Old 05-21-2008, 04:45 PM   #11
old_master
Advisor/Moderator
old_master's Avatar
Loctite will make disassembly even more difficult in the future. If anything, use anti-seize on the threads. Using vice-grips on the piston of the new shocks will damage the surface and cause the upper seal to leak. Install the lower bolts, then tighten the upper nut until the grommets squash out. If the piston shaft turns while tightening, (rare) hold the shaft with a wrench.
Old 05-21-2008, 06:04 PM   #12
bmay
Gentlemen, this is a great place to get answers! I agree old_master. Anti-sieze sounds right. What does anyone suggest to keep rust from forming over the years.
Bookmarks
Google
Web AF
