Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 04-22-2008, 09:26 PM   #1
wgazelda
wgazelda Normal reputation
Wink 2000 Vw A/c Fan
THE A/C FAN WILL NOT RUN ALL THE TIME HOWEVER, IF YOU TAKE A SCREW DRIVER AND HIT THE BACK OF IT, IT WILL COME ON BUT, THEN IT GOES OUT AGAIN. WHAT COULD THE PROBLEM BE.
wgazelda is offline   Reply With Quote
Old 04-23-2008, 04:46 AM   #2
hako
hako Normal reputation
Re: 2000 Vw A/c Fan
Do you mean the cooling fan behind the radiator that comes on when the A/C is switched on or the fan inside the heater/A/C unit inside the cabin?
hako is offline   Reply With Quote
Old 04-23-2008, 08:55 PM   #3
wgazelda
Re: 2000 Vw A/c Fan
It Is The Fan Behind The Radiator That comes on when the a/c is on
Old 04-24-2008, 06:38 AM   #4
hako
Re: 2000 Vw A/c Fan
What I'd do (and I ain't suggesting its correct) is to first check the connector which is near the fan - do this when its not working but should be - and wobble it a bit - if fan comes on the the connector is the problem - next I'd saturate the fan in WD40 or similar either in-situ or removed.
There is a relay for the cooling fan somewhere...maybe under the battery??? also check the fuses on top of the battery.
Old 05-01-2008, 12:14 AM   #5
JackDaniels386
JackDaniels386 Normal reputation
Re: 2000 Vw A/c Fan
id check the connection, like hako said, and if the connections good, id replace the fan motor.
JackDaniels386 is offline   Reply With Quote
Bookmarks
Google
Web AF
