02 ram 4.7 Dies when turn radio on A/C wont startLambdriver 04-21-2008, 03:46 AM Hello ramers My ram dies when i turn the stock radio on , the a/c light wont come on , Nore the air comes out cold I change the fuel pump thinking it was bad, I put the code reader but shows Everything Passes. When it dies it has a hard time starting until i take the battery post off and put it back on it start up again but it act as if it does not have any gas getting to the spark plugs . Can any one help????? Thanks for ready John xfeejayx 04-21-2008, 06:49 AM check the belt. bad belt/tensioning means no alternator rotation (turns off) and no ac compressor rotation (no cold air). squealing when turned on indicates bad belt/tensioning. I don't know how to explain it turning on again after you pull the battery cable. jpb53 04-21-2008, 01:08 PM On newer vehicles the radio is tied into the BUS system. With this system a faulty component on the BUS line can pull the whole system down. Unplug the radio connectors and try it for a few days and see if this is your problem. Automotive Network, Inc., Copyright ©2012
