Cam Timing Differences with D18Z6/Y8luti 03-03-2003, 03:23 PM Does anyone know the timing differences between the D16Z6 and D16Y8 engines? I acquired a Zex cam for a D16Z6 and want to put it into my D16Y8. All of the specs (lift, duration, etc) are the same between the 2 cams Zex sells for my application and the Z6. I called Zex to make sure this swap was acceptable and the rep told me it was fine, and all I would need was an adjustable cam gear and to advance the timing, but he couldn't tell me how much. Any help would be much appreciated. jcrx 03-03-2003, 03:38 PM Get a helms and check the specs. I only have the 95 so I could get the D16Z6,but not the Y8. luti 03-03-2003, 03:54 PM I have the Helms for the Y8, could you post the Z6 specs so I can compare them? jcrx 03-03-2003, 04:12 PM 16 degrees + 2 degrees BTDC at idle speed.(red dot) Automotive Network, Inc., Copyright ©2012
