Re: Tire width
You can do what is termed a "plus zero" increase in tire width. Meaning that to increase the width of the tire, you also have to reduce the aspect ratio (the height of the side wall / the tire width). This is to keep the overall tire circumference the same so that your speedometer and odometer will still be in calibration.
Physically, you should check to make sure that the wider tire won't rub on anything in the wheel well when the steering wheel is turned lock-to-lock, and when the suspension is at max compression. A tire installer should be able to assess this for you.
On a more aesthetic note, installing wider tires on narrow rims looks good only up to a point. Then they just start looking like fat balloons that stick way out of the fenders. Good luck!
Current Garage:
NEW 2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
