Rear endwishbone83 04-19-2008, 09:14 AM How do you tell the differance between a dana rear end and a chrysler rear end in a 96 xj 4x4.:rolleyes: wishbone83 04-19-2008, 06:55 PM Well i think i am going to assume that i have the Dana parts... I remooved my front axels and hubs to replace my u joints, and hubs. Spicer was stamed into the ends of the original u joints. :smokin: AlohaBra 04-20-2008, 12:40 PM Dana in front, Chrysler in rear. see FAQ: http://www.automotiveforums.com/vbulletin/showthread.php?t=598529 MagicRat 04-20-2008, 12:46 PM Get underneath and measure the axle tube diameter. the 8.25 rear has a 3 inch tube. The Dana rear has a 2.62 inch tube. Useful information: XJ's all have a Dana 30 axle in the front. In the rear, the following are options for 1996: Dana 35C with C-clips Chrysler 8.25 (27 spline) (Note on 8.25 axles - none of these axles were used on XJs with ABS brakes. If you have ABS, you have the Dana 35. Without ABS you could have either axle. 8.25 axles are c-clip) Dana 35 c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used 90-01 Chrysler 8.25 - 27 spline, 1.17" diameter shafts, 8.25" ring gear, 3" axle tube - used 91-96 wishbone83 04-20-2008, 03:56 PM Cool man thanks for the detailed info. Automotive Network, Inc., Copyright ©2012
