1998 high idlesteamplant 04-17-2008, 08:25 PM I have a 1998 villager 157K, now that the weather is warming up I have noticed the van is idling high, almost racing, RPM fluctutating between 1500-500 rpm. This happens in park and neutral, when I shift to drive it usually drops down. Now that gas is almost a million dollars a gallon, I cringe at red lights, does anyone know what the problem could be? Thanks tempfixit 04-18-2008, 12:55 AM I have a 1998 villager 157K, now that the weather is warming up I have noticed the van is idling high, almost racing, RPM fluctutating between 1500-500 rpm. This happens in park and neutral, when I shift to drive it usually drops down. Now that gas is almost a million dollars a gallon, I cringe at red lights, does anyone know what the problem could be? Thanks Check your Throttle Position Sensor, it is located on the throttle body. They are a wear item. Have you checked for any codes, Autozone and other parts stores do this for free. Get codes if any and post them. Remember that codes point to a problem area not the exact solution. Go to this site, you can download a actual service manual for your year vehicle. http://phatg20.net/index.php click on downloads, Factory Service Manuals, Nissan scroll down to Quest, agree to rules, click on year then click on download. Hope this helps vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
