HELP? Newbie needs a hand
SonyMobile
04-15-2008, 05:10 PM
hey guys,
first off I'd like to say I'm fairly new to this car audio stuff, I know a bit.. but when it comes to certain things im pretty lost.
I've bought a Pioneer P6000UB deck, a stinger 8gauge wiring kit (i know.. stinger.. but its all that I could find) A rockford Fosgate 10" P2 and... A JBL CS60.2
Now, I can pretty much figure everything out except this amp.. as I purchased it from a friend and of course he didnt have the manual or any valuable paperwork..
Now, my p2 is has dual 4ohm voice coils, how do I wire it to my amp properly?
These are the only spec's on the amp I've been able to find
* Power Output 60 watts RMS x 2 channel at 4 ohms
* S/N Ratio 86dBA (reference 1 watts into 4 ohms)
* Dynamic Power 160 watts at 2 ohms
* Effective damping factor 6.39 at 4 ohms
* Frequency Response 10Hz - 27kHz (-3dB)
* Maximum Input Signal 6.0V
* Maximum Sensitivity 100mV
* Dimensions 2.2" x 8.8" x 10.3"
PaulD
04-15-2008, 05:23 PM
since I am sure the amp is not 1 ohm stable, you really have 2 choices. 1) wire each coil to a seperate channel 2) wire the coil in SERIES and then bridge the amp.
Galuple
04-15-2008, 08:15 PM
That amp seems kind of underpowered for what the RMS handling of the sub is
new2mitsu
04-16-2008, 12:40 AM
While i agree that the amp is way low for that sub, i do think it'll still push it okay...
SonyMobile
04-16-2008, 06:50 AM
Well I know the amp is not very powerful, but I'm basically using it as a temperary unit until I get my income tax return, which is when I'll hopfully be picking up a new one. At the same time I dont want this to turn into a really big install as I don't have the budget for it at the moment, also, the car is a lease so I know all of this is going to come out within a year.
I looked on crutchfield and it showed a diagram with the voice coils wired like this Positive on VC1 to Negative on VC2, then wire the other positive and negative to a bridged amp, so I will give this a try.
new2mitsu
04-16-2008, 05:09 PM
That is what i would do
