Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Legend/RL
Old 04-13-2008, 12:07 PM   #1
vvelez209@yahoo.co
vvelez209@yahoo.co Normal reputation
Lightbulb 91 legendary legend overheating
my water pump went out after the car was running dry for almost 2 days after replacing water pump and thermostat car still over heats what could be wrong? any help would be greatly appreciated
wiseguy i pressurized the rad to 15psi ran the car for bout 5-7 min and the car gained 2psi instead of losing pressure so a leak is out also my hoses build up pressure and swell up and the rad keeps on pushing pout the water to the resvoir my cousin suggested a clog because it was only running with water and had a tremendous amount of rust on the old thermostat but before this waterpump problem the cooling system ran fine no clogs or anything aagain any help would be greatly appreciated
vvelez209@yahoo.co is offline   Reply With Quote
Old 04-13-2008, 01:02 PM   #2
Greenblurr93
Kind of a Big Deal
Greenblurr93's Avatar
Greenblurr93 Normal reputation
Send a message via AIM to Greenblurr93 Send a message via MSN to Greenblurr93
Re: 91 legendary legend overheating
try a radiator flush
Greenblurr93 is offline   Reply With Quote
Old 04-13-2008, 07:14 PM   #3
wiseguy01
wiseguy01's Avatar
wiseguy01 Normal reputation
try rad flush if rusted
wiseguy01 is offline   Reply With Quote
Old 04-14-2008, 12:04 AM   #4
vvelez209@yahoo.co
i did one before replacing the antifreeze
Old 04-17-2008, 01:11 PM   #5
fusion27
fusion27 Normal reputation
i got the same problem with my 91 legend over-heatng, also my bottom rad hose is cold and the top is hot, why is that?
fusion27 is offline   Reply With Quote
Old 04-17-2008, 01:13 PM   #6
Greenblurr93
Kind of a Big Deal
thats usually a sign of poor circulation, have you replaced the thermostat?
Old 04-17-2008, 01:21 PM   #7
fusion27
i replace the thermostat and rad and still got the same problem, could it be the haedgasket or water pump?
Old 04-17-2008, 01:23 PM   #8
Greenblurr93
Kind of a Big Deal
Yeah, a would lean more toward the water pump before the headgasket though. when the engine is cold, open the rad cap and start the car... are there any bubbles? If so, its probably a headgasket
Old 04-17-2008, 01:31 PM   #9
fusion27
ok, also my number one spark plug got oil around it, but not the tip.
Old 04-17-2008, 01:34 PM   #10
Greenblurr93
Kind of a Big Deal
not the tip? only the threads? could be the gasket that seals the valve cover around the plug
Old 04-17-2008, 01:36 PM   #11
fusion27
ok, thanks
Old 09-16-2008, 01:46 PM   #12
uribec1
uribec1 Normal reputation
Thumbs up Re: 91 legendary legend overheating
Guys,
FYI
I had the same problem with my 91 also, I took the thermostat out, flush the radiator, put new antifreeze, but nothing... so I decided to take it to this small radiator shop, they flushed it with acid, then the guy found 3 holes and a groove on radiators face. According to him, the reason it had the groove is because the fan was rubbing against it. Anyways my cost was $120.00
uribec1 is offline   Reply With Quote
Bookmarks
Google
Web AF
