Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 04-11-2008, 11:19 AM   #1
coldnsnowsucks
coldnsnowsucks Normal reputation
99 blazer 4x4 problems
I have a 1999 chevrolet blazer 4x4 with awd. everytime i try to go into 4hi it jumps to 4 low. it will not even go into 4 hi. i have replaced the encoder motor and am still having this problem can anybody please help
coldnsnowsucks is offline   Reply With Quote
Old 04-11-2008, 05:10 PM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: 99 blazer 4x4 problems
Which transfer case?
Does the shift buttons have the auto mode button?
MT
MT-2500 is offline   Reply With Quote
Old 04-16-2008, 08:39 AM   #3
coldnsnowsucks
it is the four button switch.
Old 04-16-2008, 09:14 AM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
Does one of the say auto on it?
The transfer case ID can be found on the back of it.
Is it a 233 or a 236?
DO THE BUTTONS LIGHT UP FOR A BULB CHECK KEY ON AND THE GO OFF?
Or does any stay on or blink at you?
Any check engine lights or other lights on?
We need to know which one you have before we can help.
MT
MT
Old 04-16-2008, 11:53 AM   #5
coldnsnowsucks
it does say auto on the buttons ... also it is a 236 transfer case.... and the lights do blink when key is turned on and then do go off. the transfer case will go into 4wd low on its own and is hare to get back into 4wd high or 2wd
Old 04-16-2008, 01:20 PM   #6
MT-2500
AF - Advisor
MT-2500's Avatar
OK 236 it is.
The 236 is a computer controlled transfer case and you will need a transfer case/transmissionn /engine capable scanner to test and check out and get codes.
Get the code/codes and post back code no.
MT
MT
Bookmarks
Google
Web AF
