Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 04-07-2008, 11:19 AM   #1
church1101
church1101 Normal reputation
Exclamation When i run A/C the brakes goto the floor?? Help!
Yeah... so when ever i turn on the AC and let it run a few minutes, the ABS light and the check brake light comes on, and my brakes go to the floor and barely stop me.... i need help. I have already had the ABS computer replaced and it did not fix the problem.
church1101 is offline   Reply With Quote
Old 05-20-2008, 12:36 AM   #2
NightRider88
NightRider88 Normal reputation
Re: When i run A/C the brakes goto the floor?? Help!
could possibly be a vacuum issue in the brake booster
NightRider88 is offline   Reply With Quote
Old 05-20-2008, 08:23 AM   #3
DAB77
DAB77 Normal reputation
You need to have the ABS system scanned for codes.It's not going to be a vacuum problem. No vacuum= No assist=hard pedal.
do you have this problem if you don't use the A/C? when the pedal drops, it's usually a fluid problem. Have you done brake work lately that may have allowed air into the system? Are there fluid leaks? If not I would suspect a bypass in the master cylinder.
DAB77 is offline   Reply With Quote
Old 05-20-2008, 08:28 AM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
I would suspect a electrical connection or bad ground.
Check all battery cables and ends and connections and circuit breakers and fuses.
If the check lights come on check for codes and post back code no.
Is the charging system holding good voltage and amps when it does it?
Why was brake module/computer replaced?
MT
MT
MT-2500 is offline   Reply With Quote
Old 05-20-2008, 11:32 AM   #5
Gabe25
Gabe25's Avatar
Gabe25 Normal reputation
This really sounds like your master cylinder is failing or you have a fluid leak somewhere. Ensure that your master cylinder is full. Start her up, with your AC off. Step on the brakes, put her in drive, and release the parking brake. Now keep steady pressure on the brake pedal for about a minute, and see if the brake pedal goes down. If you feel it slowly going down, re-check to your master cylinder for proper fluid level. If fluid level has no change. Then I would say that your master cylinder is leaking, and should be replaced. If fluid levels are low. Check your front calibers, and rear wheel cylinder for fluid leaks. Post back your findings.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Gabe25 is offline   Reply With Quote
Old 05-20-2008, 05:15 PM   #6
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
What "ABS computer" did you replace? If you replaced the hydraulic unit, the entire hydraulic system must be bled using an ABS capable scan tool. If you don't use the scan tool, it's impossible to bleed all of the air out and would explain the low pedal and the light coming on.
old_master is offline   Reply With Quote
Bookmarks
Google
Web AF
