97 Contour Vibrates and Shakeskforaker 04-06-2008, 08:40 AM Recently, I had the motor mounts replaced in my daughter's 97 Ford Contour. The car is a 4 CYL, Auto Trans. with 85,000 miles. When we got the car back it vibrates and shakes while idling or while driving it. At a higher speed, the vibration ( shaking ) lessens. The timing belt broke three days ago. Problem is still there after belt was replaced. Car's performance seems to be OK. Any clues? Thanks JoeShmoe 04-08-2008, 08:40 AM If the belt broke on you, that means that some of the inside components could be done. Was it just your belt that was replaced? beyondloadedSE 04-08-2008, 04:47 PM If the belt broke on you, that means that some of the inside components could be done. Was it just your belt that was replaced? The zetec is a non-interference motor, so your valvetrain is fine. JoeShmoe 04-09-2008, 09:19 AM The zetec is a non-interference motor, so your valvetrain is fine. Id didn't know that, I thought all four bangers were interference. Good to know, thanks. Automotive Network, Inc., Copyright ©2012
