Originally Posted by bubba99
There is absolutely no unusual noise on cold start. The noise on warm start isn't like any lifter noises I've had, and beleive me, I've changed out plenty of lifters over the years due to being a noise-a-phobic. Thanks for the inputs.
what is the oil pressure when hot ? is it 35-60psi...... if no oil gauge get one and monitor the pressure.... with that then it will help in finding the problem...
if it is piston problem this is usually from lack of oil/lubrication...
check fuel pressure see if you have no bleed down of fuel pressure maybe a cylinder is getting flooded on shutdown......
eventually with testing probing you will find the problem...
