Originally Posted by GTP Dad
If 1,2,3,4 worked but not 5 then I would suspect the ignition or the fan itself.
Based on my experiences Lynn you can get varying symptoms on a bad blower motor resistor (BMR) on the manual single and dual zone climate control systems.
I would suspect the BMR if fan positions 1-4 were non op and 5 worked. Also, if 5 worked and 1-4 was non-op. Also, if 1-4 and 5 were all non-op. Further, sometimes you may get only positions 1-3 and 4 and 5 non-op. On position 5 although voltage comes from the battery direct and technically not the ignition switch the blower motor high speed mini relay for position 5 is located on the BMR.
I would suspect the ignition switch right off over the BMR if there are accompanying symptoms like no DRL, headlights and IP flashing on and off with a clunking sound in the dash, no cruise control or cutting off, no hud, if equipped, no dic, etc. in addition to blower speeds 1-4 acting up.
If there are no other abnormal indications then the logical step is to replace the BMR first. At least to rule it out. If that doesn't work then go for the ignition switch.
I hope this wasn't too confusing.
