Avensis P1653 code, VSC, and Auto Transmissiondavec@r300.net 04-05-2008, 01:47 PM Hi, Please can anyone help with any information on a fault that has developed with my 2001 Avensis 2.0VVT-i Automatic. The symptoms are that the VSC, VSC Off lights come on and stay on for a while, but this fault is intermittent. The Auto transmission also sometimes stops changing up to 4th and 5th gears leaving me doing about 4000rpm at 60mph. I know these two are related as I have found threads on ToyotaNation of people that have had exactly the same issue with this car, but I can no longer view the full threads to see the solution to the problem. Toyota have identified the following codes P1653 SC V Motor Circuit C1203 Engine Control System Comms Circuit C1208 Steering Position Sensor They are suggesting I replace both VACUUM VALVE ASSEMBLYs, Parts T25860-0H030 and T25860-28070 at a cost of £305 Has anyone experienced this before? Thanks Dave Automotive Network, Inc., Copyright ©2012
