2000 Silverado 2wd vibration
I have a 00 silverado 2wd x-cab sb with a 7 inch fabtech lift, I recently developed a vibration in the driveline, being a 2wd it's only the rear. I've just had both front wheel bearings go bad, replaced both, drive shaft support bearing just replaced, tires rebalanced, still got a shake, and when you hit a bump in the road, you get a metal to metal sound, definately in the driveline, I haven't put in on the lift yet. Any suggestions? Forgot to mention that this truck has 115000 on the clock
2000 1500 2WD
7" Fabtech Lift
MT Baja MTX's on MT Classic II's
