Re: Questions about adding performance
Sorry for the delay in updating. I went through this in several stages, and I wanted to provide some measured variables for a good update.
Whell, from 10-11 mpg's up to 13-14 (Combined city/highway).
Here's part of what I did:
1) Replaced Water pump (this one was shot), and both radiator hoses (I still need to replace heater hoses)
2) Replaced both belts (engine and A/C)
3) Replaced BOTH belt tensioners
4) Replaced all idler pulleys left.(I believe there's 2 of them)
5) Alternator was checked and tested OK, so that one stayed, at least for now
6) Put in new tires (265/70/16)
7) Also replaced P/S pump
This seems to have freed engine power a lot.
I still need to replace differential and transmission fluids, as well as the transfer fluid, for a much finer metal contact in the powertrain end of my truck.
Will keep you posted.
