oil all over 4 spark plugssolidg 04-04-2008, 05:40 AM :banghead: I already read the FAQ Q: I changed my spark plugs and one or all were full of oil, what’s wrong? A: Your spark plug tube seals need to be changed. It’s an easy job and the seals can be bought from any auto parts store or the dealer. You will need to remove and replace your valve cover gasket as well. Did that still have the same problem. The well is leaking from the bottom not the top so its not the ^@()^%*I)^%(^)% tube seals. must be the tubes themselves or a cracked head?:banghead: das2123 04-05-2008, 12:10 PM What does your oil and/or coolant look like? Is either milky or muddy looking? If so, then it would be a HG leak or cracked head. solidg 04-06-2008, 08:43 AM :uhoh: coolant looks normal so does the oil i replaced the valve cover as well so a cracked head?:uhoh: das2123 04-06-2008, 02:56 PM How many miles on the HG? Last time it was changed? solidg 04-09-2008, 09:15 AM Head gasket has 20k on it The neon has 80k Automotive Network, Inc., Copyright ©2012
