Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 04-02-2008, 09:03 AM   #1
302Z28
302Z28 Normal reputation
ATF - motor oil
I have been told by several people that replacing one quart of motor oil with a quart of ATF every other oil change will provide a cleaning action and will keep the inside of the motor cleaner than oil alone.
Has anyone ever tried this? Are there any hazards associated with this procedure?
Thanks
302Z28 is offline   Reply With Quote
Old 04-02-2008, 10:34 AM   #2
muff34
muff34 Normal reputation
Re: ATF - motor oil
hazzards IMO ,if it`s a higher mileage car you run the risk of getting piston rings to clean resulting in excessive oil use. meaning it will start to burn oil.
Life Is A Highway ,Enjoy The Ride
muff34 is offline   Reply With Quote
Old 04-02-2008, 11:19 AM   #3
SLJ2137694
SLJ2137694 Normal reputation
Re: ATF - motor oil
If you properly maintain your vehicle and use quality lubricants you don't need to worry about the validity of these hand me down remedies. If you had a sludged up engine because someone didn't maintain it properly, I wouldn't want the sludge broken loose and have that crap going through the bearings and machined surfaces of my engine. The oil filter would not catch it all! As for getting the piston rings too clean, it's dirty, carboned up, stuck piston rings that give you trouble.
Retired and Loving It!!! 33 years with General Motors Product Service Engineering. A.S.E. Certified. You can fix ignorant but stupid will be a real challenge!
SLJ2137694 is offline   Reply With Quote
Old 04-02-2008, 03:29 PM   #4
Classicrocjunkie
Boosted Grocery Getta!!
Classicrocjunkie's Avatar
Classicrocjunkie Normal reputation
Send a message via AIM to Classicrocjunkie
Re: ATF - motor oil
Mobil 1 for the win.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2004 Pontiac Sunfire Coupe SE Getrag 5 speed
2009 Subaru Impreza WRX 5-door
www.Rdfabs.com
Classicrocjunkie is offline   Reply With Quote
Old 04-03-2008, 11:41 AM   #5
kirkwood158
kirkwood158's Avatar
kirkwood158 Normal reputation
Re: ATF - motor oil
I have heard and seen the results using a full synthtic oil to clean the internals out.also have heard many other rumours about adding synthtics to high mileage cars. like sluge build up on seals letting go and causing leaks .But IMO a clean motor runs cooler , synthtics are better for wear reduction , better fuel mpg's eg..less friction ,motor last longer .First you should think about a motor flush with new oil filter then add flush .Then add syntheyic and change at regular interval 3,000 miles then 5,000 then push it to 7,000 miles per oil change thus cleaning motor out. This is where I am at with my 96 grand am 156,000 miles.I have not seen oil leaks and have not noticed any great fuel increase but I dont change oil every six weeks or so any more ethier
I have tried an oil prduct from ams oil just put in my 95 grand jeep 25,000 miles between oil changes .yea we will see the start price was 200.00 for two oil changes 50,000miles and change oil 2 times for time and money savings
It claims to be very superior to penzoil synthetics which is the better on the market IMO and see charts This is not a plug just see http://www.amsoil.com
kirkwood158 is offline   Reply With Quote
Bookmarks
Google
Web AF
