flashing airbag ligthstad 04-01-2008, 06:11 PM hey good day my car is a 97 lx contour i have like 2 weeks with the air bag flashing wen the car wa turn on yesterasy the ligth started flashing wen i was on the road and dint stop today it happening agen and it dosent stop i really dont know what the problam is , i alredy change a air sencer but now the ligth is flashing faster wen befored it was like 3 or 5 at the start of the car what can i check thansk stad beyondloadedSE 04-01-2008, 08:21 PM I'm on a roll. Another one in the contour.org FAQs. http://contour.org/FAQ/FAQ.php?s=probs&displayid=29 stad 04-01-2008, 11:42 PM hey thanks i just check my car its only 24 2 times and the a pause and the 4 fast i check the info that you send but i really dont know what Safing Sensor Output Feed/Return Circuit Open what do a need to do to corrected it dugan50 04-06-2008, 04:05 PM Here's a site that will explain everything you need to know about airbag lights and resetting the system. http://www.airbagsolutions.com/ On most vehicles, the airbag light should come on for @6 seconds, and then go off if the system is working properly. If there is a fault or a problem in the system, the light will remain illuminated, or flash continuously. If the airbag light does not work properly, some vehicles have an audible tone that sounds indicating a problem with the airbag light system. When the light is on (or the tone is sounding), the airbag will NOT deploy, even in an accident. The flashing light on your car is telling the answer you need. On some vehicles, the light is flashing a two digit code. Once you know the code, you can most likely repair it yourself. There are fairly easy procedures that most people are capable of repairing. http://www.airbagsolutions.com/light.aspx This website gives you the procedure for diagnosing and resetting airbag lights. See if your car is listed here. http://www.airbagsolutions.com/vehicles_list.aspx Some vehicle manufacturers accommodate systems without a scanner (like Toyota, Lexus, Nissan, Infinity, Honda, Acura, Ford, Lincoln, Mazda & Mercury) and some require a scan tool. Check out these websites also for more info on airbag systems and the light. http://blog.airbagsolutions.com/archive/2007/11/18/why-is-my-airbag-light-on.what-should-i-do.aspx http://www.airbagsolutions.com/resources.aspx http://blog.airbagsolutions.com/ Also, you may want to check out this site for information on researching your own vehicle for factory recalls!!! http://www.airbagsolutions.com/nhtsa.aspx Automotive Network, Inc., Copyright ©2012
