Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Silverado
Old 03-30-2008, 08:25 PM   #1
Lasher66
Lasher66 Normal reputation
Hi beams and high blower do not work?
Hi,
I am new to this forum and I did search around and could not find an answer to this but I have a 2006 Silverado HD 4x4 and I cannot figure this out. My high beams do not turn on and my heater blower only works on the first three blower speeds, but when I turn the blower on the highest setting, it turns off completely. I thought this might be a fuse problem, but I checked them all and did not see any blown fuses. I noticed I have a relay fuse labeled for the high beams and same with the blower but I dont know how to check them. If this might be the problem, where can I buy the relay fuses at? Thanks for any help given.
Jason
Lasher66 is offline   Reply With Quote
Old 03-30-2008, 09:16 PM   #2
slredstorm62
slredstorm62 Normal reputation
Send a message via AIM to slredstorm62
Re: Hi beams and high blower do not work?
take out the relay and look at it. if its black or anythin change it. just go to your local parts store and ask for it. if it were the blower relay it wouldnt work at all. id go straight for the resistor
slredstorm62 is offline   Reply With Quote
Old 03-30-2008, 09:44 PM   #3
brcidd
brcidd's Avatar
brcidd Normal reputation
First, check that 40 amp blower fuse in underhood fuse block- if good then....
.....I disagree with the above-- if all you have is the lower speeds- then it is the blower motor relay- but fortunately, the repair is the same on this vehicle for any speed problems- the blower relay and the blower resistors are on the same module- the blower motor resistor module located under dash at passenger foot well- remove the hush panel and you'll see the blower motor- the wires that feed the blower motor come from the blower resistor module- plan on about $40 for it.....
For the headlights- try swapping the hi beam relay with the low beam relay- see if problem follows the relay- then replace if it does.....both are in the underhood fuse/relay center...
Automotive A/C Engineer with:
'95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone- blown head gasket
'92 Chevy Lumina Van 3.8L 264k miles
'86 GMC S-15 - 2.8L 154k miles
'86 Buick Park Ave 3.8L 199k miles- my daily driver
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles- my high school car!!
All but the Camaro and Firebird are white....
brcidd is offline   Reply With Quote
Bookmarks
Google
Web AF
