96 jetta 2l code p0135girspiggy 03-29-2008, 12:20 PM Just replace the Cat converter on my Jetta now getting code P0135 which I know is a heater fault code for the O2. I suspect may have broken a wire on the heater curcut to one of the O2 sensors during take down / install. Is there an easy way to tell which sensor may be broken or some other place to look. I tried disconnecting the forward O2 and the Rear O2 wiring harnesses one at a time and still ghet the same 135 code and then get 134 if either O2 is disconnected. I had hoped it would help me figure out which one was bad by giving different codes not the same one.. Any ideas appreciated. Doug Tatham 04-02-2008, 04:10 PM Bank 1 is the front sensor before the catalytic converter. The two wires that are the same color are for the heating coil in the O2 sensor. Unplug the sensor and put a very sensitive voltmeter to the plug coming from the car. Do not put an ohm meter to the O2 sensor, it is very easy to burn out the heating element. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
