1998 GC 2.5D Starting Problembx147 03-27-2008, 05:20 PM :banghead: Hi its Bob Grahan a newbe from Bonnybridge Scotland My Jeep GC Diesel 2.0L wont start at times the Gauges wont work on the dash or when you are driving first the speedo then the Tacograph Stops and then it does not charge and if you keep driving the battery goes flat sometimes if you stop and flick the ignition switch and all works again = So I was relieved to see a post with the same problem. Up to then I thought that I was the only person with this problem acording to Jeep = I have tried most things to get to the bottom of this but still have no answer = Sometimes when you flick the Ing Switch the lighs and gauges would come on = replaced Switch = NO change = if you keep yring to get it to go it sometimes flatens the battery = recharge Batt and it seems to work for a wee while = so I replaced the battery = Again No change = the list of what i have done and checked is endless = I even changed the Dash board as I wastold this could be a problem with the printed bit at the back = still the same = checked what I can ond wiring = still the same = Starts when you dont realy need it but if you are pushed = you just know its going to play up. = Please if you know the problem let me know = I will be dforever in yous debt = thats if I dont jump off a bridge someday when it wont start = Yours Bob :banghead: Automotive Network, Inc., Copyright ©2012
