96 altima bucking and jerking
racecar43
03-27-2008, 01:12 AM
i have a 96 altima the other morning it would crank but not start later in the day it started right up after driving it it started bucking and stalling sense it idles fine but when you give it gas sometimes it bucks like its miss firing i have checked fuel pressure it has good spark the only thing i found was the distributor has alot of oil in it could this be the problem
Handyman2005
04-20-2008, 04:17 PM
It is the oil in the distributer. Remove the distributer, get some Electronics cleaner (aerosol) and spray ALL of rge inside of the distributor. You will notice a circular piece in the middle ,, that has many tiny slits in it that a optical sensor uses to send pulses to the ECM. These have to be srayed out very well. There is an O-Ring that needs to be replaced that will keep oil from enetring the distributor. They ARE available at a Nissan Dealer , usually less than 4 bucks,. Replace that o-ring, put it all back together and your jerking engine most likely will stop. If that doesn;t work, the distributor may quite possible be bad. I did this service to my '95 and it has been fine since.(About a year and a half now. My '95 has 201,000 miles on it and it is running fine....
JoeShmoe
04-21-2008, 11:14 AM
Nice write up bro, if its that cheap I will also do my 95 this weekend. Anything specific to watch out for?
Racecar, clean out your EGR Valve with some WD40, then brake parts cleaner. Removing that buildup helps out a lot.
