Popping noise under harsh accelerationcivic1784 02-28-2003, 04:03 AM If I quickly step on the gas from a standstill or slow rolling speed in my '94 Cavalier Automatic, it lurches and there is a popping or grinding noise. What could this be caused by? However, if I am traveling at speeds over 20 and step on it, it accelerates smoothly. I'd be glad to answer any other questions that will help someone figure this out. I was thinking that it was the A/T fluid level being too low, and there not being enough pressure, but when I checked it, it was fine. This car was in an accident, it was side swiped, and that might be adding to the symptoms. The steering pulls to the right. That is all I can think of for right now. Any ideas anyone? civic1784 03-04-2003, 07:00 PM I'm surprised that no one has any ideas... *Bump v10_viper 03-04-2003, 07:36 PM I'm just guessin!!! May be that the clutch is fully engaged and your engine speed (RPMs) isn't high enough and you just flood the cylinders and it ignites and kinda grabs but I wouldn't know what exactly the popping noise is, an idea where it's coming from? Paperfish 03-04-2003, 08:45 PM it's transmission bracket/mount. civic1784 03-06-2003, 01:32 AM Originally posted by Paperfish it's transmission bracket/mount. Then why would it make that popping noise? Paperfish 03-06-2003, 01:56 AM dunno, but sounds kinda like the same thing that was wrong with my 90 camaro, got hit in front/passenger side, in order to get going from a stop i had to really gently give it gas or else it would bog down and the rpms would bounce, the car would shake, and go clunk clunk clunk., once i got going a few mph, no problem at all. was just a tranny mount civic1784 03-06-2003, 08:21 AM I'm definately going to look into that, because it was the same still of accident. Thanks. Automotive Network, Inc., Copyright ©2012
