87 s10 blazer major issues
chazmanjr1
03-26-2008, 04:00 AM
hi all. 87 blazer with a 2.8 liter 4x4.i changed the head gaskets and now it will notstart.it has good compression(110 to 120 per cylinder).i have the plug wires correct now but now have more backfire through the tbi. also no check engine light at all even when u turn the key on.so i cant get any codes. can the ecm be checked? this is my second thread and need any suggestions that i can get .thx my email is chazmanjr1@yahoo.com . chaz :banghead:
Gabe25
03-26-2008, 04:17 AM
It sound like your distributer is off. When you removed your distributer, did you mark it and replaced it in the same position when reinstalling? let us know.
chazmanjr1
03-27-2008, 12:18 PM
It sound like your distributer is off. When you removed your distributer, did you mark it and replaced it in the same position when reinstalling? let us know.i never removed the distibutor
didnt have too.thx chaz
randy78
03-27-2008, 03:17 PM
read this:
http://www.automotiveforums.com/vbulletin/showthread.php?t=881442
hmm interesting, but you have to remove the distrib to remove the intake to remove cylinder heads in order to replace the head gaskets
make sure all sensors are plugged in
make sure all ground wires are connected and tight on the block and such
set engine to TDC of compression stroke in number one cylinder
see that the distrib rotor is pointing at your number one wire
the intake has a large cast raised number on each intake runner by the valve covers make sure that the wires to each of these cylinder numbers is going to the right distrib cap tower(in the same order as the firing order of the engine)
make sure timing is set at least close enough to run
it may just need turned a bit is all
it is probably off just more than enough to make it not be able to run
the rotor needs to be at the number one tower on TDC #1 of compression stroke and actualyl a hair past it(advanced a little bit)
counter clockwise with the cap will advance the initial timing
clockwise will retard it
since the rotor turn clockwise in gm engines
but anywhere close to it should allow it to run
110 to 120 isnt all that great but its ok for a real high mileage engine i suppose
150 would be more closer to normal though
good luck
Gabe25
03-27-2008, 06:13 PM
I agree with Randy78, Recheck your timing marks. Check your presets making sure that you are TDC on cylinder #1. Then place your distributor so that your rotor is on or near #1 firing on the cap. Make minor adjustment as need in trying to start your motor. Let us know how your doing.
chazmanjr1
03-28-2008, 11:24 AM
I agree with Randy78, Recheck your timing marks. Check your presets making sure that you are TDC on cylinder #1. Then place your distributor so that your rotor is on or near #1 firing on the cap. Make minor adjustment as need in trying to start your motor. Let us know how your doing. Thx guys ill keep in touch
:banghead:
Gabe25
03-28-2008, 02:00 PM
Your Welcome. Just let us know.
chazmanjr1
04-04-2008, 08:36 AM
Your Welcome. Just let us know. im still working this thing out all thx so much u guys r really helping alot.ill keep eo informed.chaz
