Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Silverado
Old 03-25-2008, 04:07 PM   #1
super85sport
super85sport Normal reputation
04 silverado driveline vibration
Ive got an 04 silverado z71 extended cab i am having some trouble which seems to me like a driveline vibration. Ive checked u-joints ball joints tie-rods replaced tires had them dynamic balanced. It occurs all the time but is more noticeable it highway speeds. The truck shakes and shudders and i can feel it in my seat in in the floor which kinda leaves me to believe its coming from the rear. I could really use some help this problems been driving me crazy for a year. Ive had it back to chevy 3 times and they say they cnt find anything wrong. Just wondering if anyone else has expierinced this
super85sport is offline   Reply With Quote
Old 03-25-2008, 06:51 PM   #2
chuck16
chuck16's Avatar
chuck16 Normal reputation
Re: 04 silverado driveline vibration
2 things:
1) Have you had your wheels and tires balanced recently? It's amazing how improperly inflated tires and out of balanced ones can effect your ride.
2) The phrase "Frame Beaming" has been brought through here from time to time regarding this problem so you may want to research that phrase and see if anything helps. I haven't seen a solution in regards to this one but, it's something that is apparent in some trucks...
Hope that gives you some direction to look...
99 Silverado, 3 Door, Whistler/Blackcomb Special Edition
Magnaflow Single in Dual out Exhaust w/Flowmaster Resonator,
AEM Brute Force CAI,
Modded Automatic Headlights,
4 Headlight Mod,
Hella FF100 Driving lights
Green LEDs in Headlights,
Clifford Alarm,
Silverstar Low, XENON High Beams
NWSilverado
I AM Canadian!!
chuck16 is offline   Reply With Quote
Old 03-25-2008, 07:08 PM   #3
Bob731
Bob731 Normal reputation
chopped tires, tranny mount, bad belt in tires, check the rear axle fluid,
Bob731 is offline   Reply With Quote
Old 03-25-2008, 07:47 PM   #4
super85sport
The tires are brand new as were the tires that were on the truck when I bought it. Ive had them balanced severeal times at different places because I didnt trust the ford dealer i bought it from. I always make sure they're properly inflated and rotated as i was a gm tech for several years. Ive changed the transfer case fluid as well because i knew that had been a problem before. Ive never heard the phrase you used before so i will reasearch it. thanks for the input and info
Old 03-25-2008, 08:22 PM   #5
j cAT
j cAT Normal reputation
some things that I think are important.. all tire sizes/wear the same? is this in 2wd...? are the tires wearing perfectly..??? did you check the drive shaft for balancing weight falling off???
did you/dealer remove rear brake rotors inspect rear wheel bearings..... was the vehicle in accident and the rear wheel was hit[bent axle] been there done that ??????
Did you consider having another mechanic inspect for this issue....??
j cAT is offline   Reply With Quote
Bookmarks
Google
Web AF
