Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 03-24-2008, 10:22 AM   #1
grampsVVV
grampsVVV's Avatar
grampsVVV Normal reputation
99 Astro Cargo ABS
1999 Astro ABS kicks in during normal stops. A rotted rear brake line was recently replaced and new front rotors and pads installed. There's no evidence of leakage along the lines or at the master cyl. Ideas?? Thanks, in advance.
grampsVVV is offline   Reply With Quote
Old 03-25-2008, 01:43 PM   #2
dewaynep
dewaynep Normal reputation
Re: 99 Astro Cargo ABS
You've got a wheel speed sensor that is dropping out at low speeds. Probably one of the fronts since work was recently done there. Easy enough to check: Disconnect the wheel speed sensor connector. Put a meter across the 2 leads. You should get a pretty steady 300mv or so from each sensor when the wheel is spun by hand. Left to right voltage should match pretty closely.
dewaynep is offline   Reply With Quote
Old 03-25-2008, 08:51 PM   #3
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
If the ABS unit runs dry, as yours did when the line failed, an ABS capable scan tool MUST be used to bleed the system. If you bleed the system without using the scan tool, you cannot bleed all of the air out of the ABS unit.
old_master is offline   Reply With Quote
Bookmarks
Google
Web AF
