clutch problem. please help.clipse_thumper 03-23-2008, 09:22 PM okay, I have a 5spd 2001 325CI with 120k miles. for about a month i've noticed that when I step on the gas all the way, my rpm's fly then come back down to normal. well last week, the rpm's started bouncing, when I steped on it, it would hit 6500 rpm's then drop down to normal then go back to 6500 rpm's and so on but only if I floored it. finally on my way to work the other day I was in 5th gear the whole way till I had to exit and I smelled a burning smell. I heard like a rumbling sound, I took it out of fifth but I couldn't get it into any other gears. so I cruised to the red light, turned the car off, put it in 2nd gear and turned it on in 2nd and drove the rest of the way. I only had a block from my highway exit. I have no clue what the problem is. if its the clutch I thought I wouldn't be able to drive it at all. I checked the fluid and it was normal. but I smelled that burnt smell for a few hours. any idea's? if it is the clutch, how much do you think for replacement through a mechanic?. thank you, anything will help GTmike400 03-23-2008, 09:58 PM Clutch is gone. You'll need a new one. Replacement will cost about $800 or more, unless you do it yourself. clipse_thumper 03-23-2008, 10:38 PM how hard is it to replace yourself? if it ain't to hard, where can I get a step by step on how to replace it? moon03 05-05-2008, 01:55 PM the clutch set is about $200 and some kits come with the alignment tool. job is not all that difficult if you have done clutch replacements before or replaced an engine or transmission. I use a Bentley Shop repair manual for the procedures, or a Haynes manual. (I have both and plenty of time) also check local transmission shops preferrably one with 4 or more bays as they are more likely to have done BMW clutches before and can get it done faster. just make sure they use quality parts. you may want to think about the timing belt replacement at the same time if your doing the job yourself and it hasn't been done reciently. Automotive Network, Inc., Copyright ©2012
