Help finding parts
jyguy915
03-23-2008, 03:35 PM
Hi, I have the notorious coolant leak that requires you to change out the 0-rings in the two pipes thats in between the intake manifold, I have trouble finding those O-rings for the two pipes, can someone tell me where I can find it or the part numbers for them are? thank you I have a 1995 honda passport 3.2l v6
Gizmo42
03-23-2008, 05:28 PM
Not really sure if this is the right one. But if you do a part number search on myisuzuparts.com you should get an exploded drawing of all the parts and be able to find the right one. Click on the drawing number and it will take you to the list of part numbers.
GASKET; HSG TO PIPE 9-09561-220-0 1 11-1992 to 03-1997
After the part search click on the camera icon to the right for the year and model of your rodeo to bring up the exploded drawing.
okmech1
03-25-2008, 08:32 PM
I had to replace mine just a few weeks ago. I have a 2001 3.2L, so I don't know if it's the exact same, but I got a few part #'s :
9-09561-225-0 o-ring
8-97136-346-0 gasket (2ea)
I got these from Folgers Auto in Charlotte, I can Private msg you the info if you need it.
If your model is similar to the '01, just above the timing belt covers is a crossover manifold looking thing that has a few attach bolts. When you slide this off, there is a gasket for each of the ports going to one side of the block(attach bolts go through these gaskets) and the dreaded o-ring was on the pipe coming from underneath the intake plenum going into this same manifold.
Hope this helps
jyguy915
03-27-2008, 02:34 PM
thank you all for your help, i was actually able to get all the parts from my local dealer. once again, thank you, you guys are the best.
