Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 03-22-2008, 08:55 PM   #1
Gerard822
Gerard822 Normal reputation
1992 Asto van won't start...HELP
Help! Have 1992 Astro Van. Just changed the starter, battery is fine. Went to the store, came out 5 minutes later and won't start. No power at all, lights don't come on. At first, the dinging noise from the key being in the ignition was on, only sign of power in the thing. Then I moved the steering column and that went too. Any ideas?? Please help, this is our only vehicle and I have to use it for work.
Thanks
Gerard822 is offline   Reply With Quote
Old 03-23-2008, 01:08 AM   #2
Corndog Man
Corndog Man Normal reputation
Re: 1992 Asto van won't start...HELP
Thanks
My 1993 Astro CL has something similar but it will start. When I turn the ignition key, I get a click and the engine doesn't turn over. Sometimes it will take couple of turns of the key, then it starts fine. It's not a starter problem. I wonder if it's my ignition switch.
A couple of hits on the key won't start it I take it?
Corndog Man...
1939 Master 85
1990 Cub Cadet 1541
1999 Lumina LTZ
2004 Avalanche Z-71
2007 Sky Redline
2009 Pontiac Vibe GT
Corndog Man is offline   Reply With Quote
Old 03-23-2008, 07:52 AM   #3
CD Smalley
CD Smalley Normal reputation
Sounds like the switch to me. Mind you this isn't where you put the key in. It's mounted to the top of the steering column and controlled by a rod connected to the key-lock.
CD Smalley
1991 W41 #142
1995 Astro
1989 Caprice 9C1
1997 C1500
1977-90 GM B-Body email list Owner @ yahoogroups.com
In the recovery room: b-body.org...
CD Smalley is offline   Reply With Quote
Old 03-23-2008, 12:30 PM   #4
Corndog Man
Hey thanks! I didn't mean to hijack this thread. It sounded similar. Mine has been doing it for years. The van has 200K on it and has limited use.
Corndog...
1939 Master 85
1990 Cub Cadet 1541
1999 Lumina LTZ
2004 Avalanche Z-71
2007 Sky Redline
Old 03-23-2008, 02:41 PM   #5
Gerard822
Ok.
Went To Get The Astro And Played Around With The Column And Ignition Switch And She Started Rite Up. Got Home Turned Off And On A Few Times No Problem. Any Ideas Mybe Ignition Switch Or Wires?
Old 03-23-2008, 06:07 PM   #6
CD Smalley
Still bettin gon the switch. My 95 did the same. It would be good for days. Then it would take 5-6 tries before it would start, then more and more.....
CD Smalley
1991 W41 #142
1995 Astro
1989 Caprice 9C1
1997 C1500
Bookmarks
Google
Web AF
