93 Accord EX Temperature Gauge Problem
My temperature gauge was on Hot and the two fans were turning with no A/C running.The moment I stepped on accelerator the needle immediately came back down to normal and fans turned off.
I drove the car home with the gauge going up when I was stopped but back to normal upon acceleration. A block before my house the check engine light came on and the motor was running a little rough. I shut it off in the driveway,checked fluids which were fine and started it up again.The engine ran fine but the gauge continued climbing at idle and back to normal with acceleration.This morning I started it up and everything worked fine for about 20 minutes then it started doing it again with the gauge. The check engine light never came on again except for the one time.I changed the thermostat 35,000 miles ago with a new one from Honda. I am wondering if the temperature sensor by the top radiator hose is bad. I don't show any records of it being changed. Any thoughts?
