95 Neon Fuel Pump Fuse
Oldsmobile Doctor
03-20-2008, 04:02 PM
I have a 95 single cam Neon that I put a 99 twin cam engine in my question is it blew a fuel pump fuse is this a clue of pending doom for the fuel pump or just more bad luck
das2123
04-05-2008, 12:12 PM
Did you check the wiring to the downstream O2 sensor? It can ground out and blow the fuel pump fuse.
Oldsmobile Doctor
04-06-2008, 09:21 PM
Just came in from fixing, the connector for the downstream O2 sensor came off the alternator braket and fell onto the axle rubbing the insulation off the power & ground wire. Thanks for the reply
