93, Vandura won't startalbee9 03-20-2008, 03:43 PM My problem started when I started getting black smoke from the exhaust so i thought change the spark plugs which were very fowled just to get it home . but still black smoke so i changed the fuel injectors still hard to start so to make a long story short . I have replaced : the spark plugs,the wires distributor,rotor, the ignition coil,EGR solenoid ,and fuel injectors and it still won't start . I'm getting spark and fuel haven't checked compression yet. Please help thank you for your time maxwedge 03-20-2008, 04:13 PM Is the fuel pouring in uncontrolled, any check engine lite, do you have good compression? albee9 03-20-2008, 06:23 PM Is the fuel pouring in uncontrolled, any check engine lite, do you have good compression? check engine lite does what it would normally yes good compression fuel seem to be spraying in like it should. question? what's the deal with a blue spark? I get some what of a white spark. the van acts like it wants to start but just won't . albee9 03-25-2008, 04:52 PM Well the saga continues I checked the timing and that seems to be right on Automotive Network, Inc., Copyright ©2012
