Control arm boltszakkwylde89 03-20-2008, 02:05 PM Apparently the boltss came out from my 1990 honda accord ex's control arm and the car is pulling hard right. If i go to pull a part and get the bolts from like a 92' or 93 accord would they fit?? Greenblurr93 03-20-2008, 02:30 PM as long as the bolt has the same thread pitch youll be good lessthanwise 08-22-2008, 05:17 AM just ask for a 17mm control arm bolt wreckchord 11-28-2008, 02:01 AM Apparently the boltss came out from my 1990 honda accord ex's control arm and the car is pulling hard right. If i go to pull a part and get the bolts from like a 92' or 93 accord would they fit?? it works, but i think the part that bolts onto the shifter is a lot smaller, so you will have to either use the da shifter or bend the holding piece wider to fit your eg shifter on there..gl..but it does fit and does work fine too! Automotive Network, Inc., Copyright ©2012
