Idle problem 1999 Rodeo 3.2 automatic 2wdFred007 03-19-2008, 04:36 PM Hi, hope someone can help. I have a 1999 isuzu Rodeo 3.2 6cy, automatic 2WD with 107000 miles. The engine suddenly began to idle @ 2000 rpm. No check engine light. I have replaced several devices such as, the ICV idle control valve, four 4, co2sensors, EGR sensor, and the Mass Air sensor. After each item was replaced the engine ran at a low 800 RPM for a day or two and then went back to 2000 RPM idle. On none of the occasions did the check engin light come on.:banghead: FL 3.2L 03-19-2008, 04:46 PM Vac leak. IMG. amigo-2k 03-19-2008, 04:57 PM I agreed. Fred007 03-19-2008, 05:02 PM Thanks FL 3.2 Can you elborate on the vac leak MIG. I have checked all of the lines that I can see. What is MIG? Fred007 03-19-2008, 05:29 PM What is MIG? klvaleri 03-19-2008, 05:49 PM What is MIG? MIG=Manifold Intake Gasket. This is very common failure on our truck per Amigo-2K. FL 3.2L 03-19-2008, 07:38 PM Look in the faqs for intake manifold gasket leak. Automotive Network, Inc., Copyright ©2012
