Double wishbone suspension
ales
02-27-2003, 04:08 AM
I know it's the best sporty setup. Can someone tell me why?
And also, how does one go about tesigning the setup? I mean the lenghts of the lower/upper A-arms, and also the length of the forward and rear rods in the a-arms. And also all sorts of angles (vast question, I know). I'm just very very curious to learn as much as possible, hope you don't mind my questions (and I have a lot of them to come! :D)
Thanks,
Alex
FYRHWK1
02-27-2003, 11:45 AM
Double wishbone suspension is the best setup because it reacts to bodyroll less then any other type of independant suspension, they also let you have a large amount of vertical travel without the wheels angle (camber) being changed, the C5 corvette fo example, it has 0 camber change through 95% of its vertical travel, it uses a double wishbone setup. the other types of independant suspensions are trailing & semi trailing arm, swing axle, and multi link, they just use different ways of controlling the wheel and how they attatch to the structure of the car.
454Casull
02-27-2003, 04:23 PM
I wouldn't say it reacts less... I'd say that the wheels maintain more surface area on the road.
Body roll isn't the only thing double wishbone suspension is good at. Bumps and stuff are easily absorbed too.
ales
02-27-2003, 04:28 PM
So is it as good for luxury cars as it is for sporty cars?
454Casull
02-27-2003, 07:33 PM
Yes. Better handling benefits us all. But double wishbones do take up more space than, say, MacPherson struts, and leg room is definitely higher up on the Good Things list for luxocars than sports cars.
ales
03-02-2003, 01:45 AM
So when designing this kind of suspension, what are the benefits/downsides of having 1 wishbone longer than the other?
Deakins
03-02-2003, 05:35 AM
The camber angle remains nearly unchanged when you have body roll.
The downside is the chamber angle change at bumps.
911GT2
03-02-2003, 12:14 PM
Nonparallel unequal length arms just happen to have less camber change (larger contact patch).
This should help explain: http://autozine.kyul.net/technical_school/handling/tech_handling_1.htm
FYRHWK1
03-03-2003, 06:45 PM
by reacts less I mean that the contact patch stays relatively unchanged, although it does happen, and bumps are just sudden vertical travel.
