95 explorer 4.0 4x4 power problem
meow700
03-16-2008, 04:51 PM
I have a 95 explorer eddie with the 4.0L with approx 155k. I just replaced the plugs and wires and put in a fuel filter. I have checked compression and all cylinders range from 135-150 and had the catylitic convertor checked. The explorer still has no power its all it will do to maintain 65mph and any incline it shifts out of overdrive. Any suggestions would be greatful
way2old
03-16-2008, 05:39 PM
What is the fuel pressure?
shorod
03-16-2008, 06:49 PM
Have you checked the air filter and cleaned the MAF sensor? Has you fuel economy changed? Is the engine running smoothly, just with little power?
-Rod
meow700
03-19-2008, 04:08 AM
it has a new k&N filter, i have experienced mpg loss, the motor runs great but just has power loss, and no i have not had the fuel pressure checked.
shorod
03-19-2008, 11:22 PM
That may be the key. Oiled air filters are notorious for contaminating the MAF sensor. A contaminated MAF can certainly cause loss in fuel economy and may be the reason for the lack of power. I would suggest you start by very carefully cleaning the MAF sensor.
-Rod
