A little adviceJamieR 03-16-2008, 01:18 PM I just got an older 86 4Runner 22RE and she is not doing so well. On start up it coughs a little every once in a while and takes a little while to start. Once she goes seems okay except for the odd little stutter which you really have to listen for. But when I put her in gear she sputs, coughs up some black smoke and just generally does not want to go anywhere. I checked the plug wires and they seem okay. The distributer seems fine too. I have not removed any plugs yet as I need an extension. Any suggestions as to what it may be if not the plugs? Brian R. 03-16-2008, 10:47 PM My first guess is the ignition coil. Injectors may be dirty. Check the compression. See if the plugs are nasty first. JamieR 03-20-2008, 04:16 PM Hey Brian thanks for the advise, I did get in and change the plugs and well they were really not bad at all. I little black but not worn. My ride seems to be running fine now, starts easy and doesn't miss a beat. I also put in some injector cleaner on this tank of fuel. So far it's back to normal so I don't know what to think about this little event of sputtering but I guess if it happens again I will look at the ignition coil. rsterling@lcps.k12 04-17-2008, 03:31 PM Ihave the same motor , my problem was a injector was totally clogged ,I HAD TO PULL the injectors out and have them cleaned. :grinno: Automotive Network, Inc., Copyright ©2012
