Re: weird guages
Sounds like you have a malfunctioning fuel sender unit which is part of the fuel pump assembly located inside the fuel tank. As far as the oil pressure gauge, well, it is not really a gauge but a switch. What you read from the gauge is not the actual pressure but only the presence of adequate pressure. I suspect that the switch, located forward left lower corner of the engine block, is malfunctioning. It is not an expensive device to replace.
