Re: Rotate Crankshaft Backwards?
Thanks Cat,
We've been working on the engine, changing the head gasket, new belts, water pump, etc. and somehow my helper turned the crank before we got to replacing the timing belt. I put the belt on and tried to line up the camshaft mark with the valve cover mark and it stopped moving. I know that when we put the exhaust cam back on it didn't 'set' in with the mark straight up like when it was taken out. I was hoping I could rotate the crank backward and try to get everything to line up. Will that work? Thanks again.
