Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 03-12-2008, 01:30 PM   #1
AmberM21
AmberM21 Normal reputation
Dim Headlights, Check Engine Light On
Hello All: 2001 Cav
My check engine light has been on and off for the last few months. I went to my mechanic and he did a diagnostic test on it, said it was a faulty gas cap seal. I replaced the gas cap and the check engine light went off for a few weeks but came back. Recently, my headlights have been becoming more dim. I replaced the headlights and they're still dim. Any suggestions? I plan on changing fuses this weekend to see if that fixes it.
AmberM21 is offline   Reply With Quote
Old 03-13-2008, 12:37 AM   #2
Jacfourteen
Jacfourteen Normal reputation
Re: Dim Headlights, Check Engine Light On
I hear that the headlight harnesses in these cars sometimes rub through, so check that. also check for corroded grounds and terminals. If all that checks out I'd take the battery and/or the alternator in to be checked, many parts stores can check them on the vehicle. Hope this helps.
99 Explorer (my daily driver)
-2" lift, 31" tires
-Magnaflow muffler
-7" Touch screen DVD stereo
-12" drop down LCD monitor
02 Mustang Convertible (wife's)
-K&N Filter
-Flowmaster 50
68 GMC (project)
-300 HP 350
Jacfourteen is offline   Reply With Quote
Old 03-13-2008, 01:58 AM   #3
RaeRae1
RaeRae1's Avatar
RaeRae1 Normal reputation
Send a message via AIM to RaeRae1
I would say alternator as my first guess. They can create many gremlins within the electrical system when they start to go and can throw strange error codes. Have that checked first. Battery would be my second guess.
Blessed are the cracked ones, for they are the ones that let in the light.
Originally Posted by 72chevelleOhio
Your cheer-mobile needs a flat tire.
RaeRae1 is offline   Reply With Quote
Old 03-14-2008, 12:09 AM   #4
aimforcody
aimforcody Normal reputation
Send a message via AIM to aimforcody
yea alternator, then battery
aimforcody is offline   Reply With Quote
Old 03-14-2008, 12:14 PM   #5
AmberM21
I probably should have mentioned that I'm like 3k over for an oil change. When I get it changed this weekend I'll ask the mechanic to check the alternator but the battery is only about 18 months old. Thanks everyone!
Old 03-17-2008, 01:48 PM   #6
jetblacknewyear
jetblacknewyear's Avatar
jetblacknewyear Normal reputation
I had this problem a month ago.
Check to make sure you have the right headlights installed. I bought the 9006 model and my car really needed the 9007 model. It fixed that problem right away.
jetblacknewyear is offline   Reply With Quote
Old 03-28-2008, 12:06 PM   #7
AmberM21
I have the 9007s installed but they're still pretty dim. I can see maybe 15 feet infront of my car with the regular lights, 25 with the bright.
Old 03-28-2008, 12:39 PM   #8
o0kev0o
o0kev0o Normal reputation
u can check ur alternator pretty easily with a standard volt gauge just start the car turn as much electrical users on as u can (wipers lights radio)check between the battery terminals should get about 14vdc if its lower than 13vdc its probably the alternator if its good turn the car off and check the voltage again after turning every thing off u should stay at 12.5 or more
o0kev0o is offline   Reply With Quote
Old 03-29-2008, 01:54 PM   #9
aimforcody
sounds like a wiring problem, check all your connections for corrosion, clean all that you find with vinager and a wool pad, be safe about it obviously, don't "cross clean", you know clean a live wire and the ground, could cause some burnage =P also check fuse under hood for corrosion.
Bookmarks
Google
Web AF
