Programming 99 Bonneville SE Keylesstjhendr 02-26-2003, 05:21 PM Does anyone know how to program the keyless entry remotes on a 99 Bonneville SE? Any help would be appreciated! Scott 02 02-26-2003, 08:43 PM :rolleyes: Send John a PM. He will be your best help. ;) DePereRob 02-26-2003, 10:42 PM I got this info from this site. It worked for my 1997 and 1999 Bonnevilles. Good Luck. NOTE: You must have the correct part number on the remote for it to work. I have some spares I'd be willing to sell for a nominal price plus shipping. My family owns a large salvage yard and one day I foraged through all the cars and got a pail full of Keyless Remotes. The part number you need is 15732803. Transmitter programming per the GM manual: Important: Before entering the programming mode, verify the possession of all the transmitters you will be using on the vehicle. Once you program the transmitter, the memory erases the other transmitters. You may program up to 4 transmitters 1) Turn OFF the ignition switch 2) Usa a fused jumper (3 amp is sufficient) and connect terminal 8 (back/white wire) to terminal 4 (black wire) 3) Close all the doors 4) Turn ON the ignition switch the doors will lock 5) Press and hold the following buttons on one of the transmitters for 30 seconds: lock and unlock 6) After a 30 second delay, the doors will lock and unlock Important: DO NOT turn OFF the ignition . If the switch is turned OFF the first transmitter becomes inoperative. 7) In order to program extra transmitters repeat Step 5 8)Disconnect the fused jumper wire from the data link connector 9) Turn off ignition 10) Verify functions of all programmed transmitters. Shortbus 02-27-2003, 09:07 AM Thanks DePereRob That is the correct way to do program the rke receiver. Here is a pic of the DLC connector you will need to find at the knee bolster. http://files.automotiveforums.com/uploads/779097CONNECTOR.jpg fuelmaxman 11-19-2007, 10:56 PM hey dude, very useful info. i have a 97 bonneville, and my car won't even lock the doors when i jump 4 and 8 together! but i know that i also have the wrong transmitter from what you said. mine is # 10246216 and i also have a 99 grand am that needs to be programed and the fob i haave for that one is # 25668603.. is the grand am one the right one and how much do you want for the one i need for the bonneville? my number is 920-712-6108.. don't know if i'm supposed to do that but give me a shout and i'll try work something out with ya. Onblsht 11-23-2007, 10:52 AM Neither are correct. You can use FCC: KOBUT1BT with part # 25678792 for both the 97 Bonneville and 99 Grand Am. fuelmaxman 11-30-2007, 10:58 PM cool, thanks for the info, could you send me a couple of key fobs for the 99 grand am and the 97 bonneville, it said that you had a few for sale, and i would gladly work out a deal with ya. ralphwilliam07@com 09-12-2009, 09:27 AM :sarcasmsign:Does anyone know how to program the keyless entry remotes on a 99 Bonneville SE? Any help would be appreciated! HotZ28 09-13-2009, 11:16 PM :sarcasmsign:This thread was started back in 2003; not much need in posting :sarcasmsign: six years later!! ghalacsy 02-17-2011, 09:14 PM I have a 99 sle and when i jump #4 and 8, followed instructions and no door lock or unlock. wat could be causing that? my brother had a keyfob for it when he got it and it went bad. thus the attempt to program new one. Onblsht 02-17-2011, 09:41 PM Make sure you are using the correct slots in your DLC (see the diagram a few posts up). Also, make sure you are not pressing the brake pedal at all during the procedure. ghalacsy 02-17-2011, 09:49 PM No foot on brake pedal and I did have it in the correct slots. just t make sure i repeated the process in my 96 park ave. and everything went as it should. That's why I am stumped. I got no lock and unlock of the doors at all when i turned the key to the on position. Onblsht 02-17-2011, 09:53 PM Try the procedure with all doors closed first, and if that doesn't work, try with the driver's door open. If no response, you may have a blown fuse or bad receiver module in the vehicle. ghalacsy 02-17-2011, 09:57 PM I tried it with door both open and shut, nothing. So I'll check the fuse next, and how do I replace the module, is it in the door? It's been a while since I've had to mess with that. ghalacsy 02-18-2011, 09:23 AM If it is a module that went bad, would I replace the door module or the Body Control Module? I have both out of a 97 park Ave., would that work? Thanks Automotive Network, Inc., Copyright ©2012
