Re: duramax fuel
I think you meant "reset oil filter life":
GM Oil Life System Resetting
When the system has calculated that oil life has been diminished, it will indicate that an oil change is necessary. A CHANGE ENGINE OIL SOON message will come ON. Change the engine oil as soon as possible within the next 1 000 km (600 miles). It is possible that, if driving under the best conditions, the oil life system may not indicate that an oil change is necessary for over a year. However, the engine oil and filter must be changed at least once a year and at this time the system must be reset.
If the system is ever reset accidentally, change the engine oil at 5 000 km (3,000 miles) since last oil change.
How to Reset the Engine Oil Life System
Turn the ignition key to RUN with the engine OFF.
Fully press and release the accelerator pedal 3 times within 5 seconds. If the OIL LIFE RESET message flashes for 10 seconds, the system is resetting.
Turn the key to LOCK.
If the CHANGE ENGINE OIL SOON message comes back on when you start the vehicle, the ENGINE OIL LIFE SYSTEM has not reset. Repeat the procedure.
92 BMW 325I 171k
97 Saturn SWII 173k
98 Pontiac Transport 171k
03 GMC Sierra 35k
