Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 03-12-2008, 01:14 AM   #1
driver42484
driver42484 Normal reputation
96 cavalier 2.2 weird no start problem
The car will start and run if i jump the terminals on the starter. I checked the yellow wire from the ignition switch and it has a constant 12 volts.... It shouldnt have this. Turn the key and it dosnt change. I checked the purple wire and its not getting power with the key on off or in the start position. The yellow wire has power even if there are no keys in the car and its off etc.... So is this the netrual safety switch and the ignition lock? I dont want to start buying parts until im sure about the problem.
The owner of the car has a flooded driveway and the water is about to the top of the tranny. She had to blast through it not to get stuck. Did the water short the switch and the ignition lock??? Any help would be great
Thanks
Kip Kilmer
driver42484 is offline   Reply With Quote
Old 03-12-2008, 08:23 AM   #2
back2life
back2life's Avatar
back2life Normal reputation
Re: 96 cavalier 2.2 weird no start problem
retest from area in the column under dash after the ignition switch . if im correct tho,i think the purple is the starter trigger. hopefully someone will confirm
CHECK ME OUT AND SIGN MY GUESTBOOK!
http://members.cardomain.com/back2life2
back2life is offline   Reply With Quote
Old 03-12-2008, 12:32 PM   #3
jdl
jdl Normal reputation
If we're talking about the same yellow wire. That wire goes hot with the ignition switch in the crank position. It shouldn't be hot all the time. Then from the neutral switch (automatic) to the ignition terminal on the starter solenoid, the wire is purple. Have you tried cranking the vehicle in neutral?
I saw your other post about using the wrong key. I'm not sure what that might have done to the theft system, not to mention the key cylinder or ignition switch. My information shows you have passlock theft system, that system has no effect on the starter circuit. It should still crank, if everything else is ok.
jdl is offline   Reply With Quote
Old 03-12-2008, 11:53 PM   #4
driver42484
Yes the yellow wire from the ignition that shouldnt be hot is hot at all times. I think it got shorted out or something when she drove through the puddle. I just dont want to start throwing parts on the car and still have one or two more things wrong.
Old 03-13-2008, 08:28 AM   #5
back2life
back2life's Avatar
hey jdl, you got any info on getting the passlock bypassed on my 96 that wont start? (theft light on with no start)?
Old 03-13-2008, 02:33 PM   #6
jdl
If your saying the starter won't crank, I don't think it is the theft system. If it cranks good and the theft lite is flashing. Have you tried a different key? Are there any codes? With the key on, will the theft lite eventually go out, may take a several minutes. If/when it goes out, will it then start?
There is some theft information, here, go to smpcorp.com then click on engine mangement link, click standard products, when that page comes up, click on tech info in left column. There will be a box that says (select symptom) a whole page of stuff, scroll down to ( computer relearn procedure ) there may be some information there that will give you some ideas. Sorry about all the links, my cut/paste didn't work. I don't know how to bypass that system.
I believe I saw some kits on the internet, for bypassing that system. Try a web search.
Old 03-13-2008, 03:03 PM   #7
back2life
back2life's Avatar
it cranks all day! theft light is on solid will not even go off in the relearn procedure. i just dont understand it. guess im gonna have to tear into the column
Bookmarks
Google
Web AF
