No shift until car warms up .. 94 deville
vking76
03-11-2008, 11:19 PM
hello all, I have a 94 devill that wont shif when its cold ... I put it into any gear and acts like its in neutral.
After the car warms up ... usually a minute or two, it operates perfectly fine. No slippage while driving. If I let it sit long enough during the day, when I come out after work it does the same thing.
Any ideas on a remedy?
Thank you
83cutlass
03-12-2008, 06:59 AM
Sounds like the torque converter is draining back overnight. My Jeep was doing this for a long time and then one day the the front seal blew out. I replaced the front pump seal and bushing and it hasn't done it since. However I'm not sure it this applies to your 4T60e trans because thats a lot different. I'll do a little research and see if I can come up with something.
DFBonnett
03-12-2008, 11:22 AM
This is not uncommon with this trans. First, check the fluid level. If that's OK, drop the pan, change the filter and fluid. Do not "flush" the trans w/o changing the filter. That will likely do it. If it doesn't you're only out about $30and you can pursue more complicated and costly scenarios.
