Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 03-11-2008, 09:05 PM   #1
grave digger
grave digger Normal reputation
left headlight
2003 Cav LS Sport Coup I noticed the left headlight was very dim. I installed a new bulb and it is still dim. all other lights work normally with the exception of a right side marker light is burned out. All of the connections are clean (no corrosion). Can anyone help? Thanks in advance.
grave digger is offline   Reply With Quote
Old 03-11-2008, 10:49 PM   #2
Classicrocjunkie
Boosted Grocery Getta!!
Classicrocjunkie's Avatar
Classicrocjunkie Normal reputation
Send a message via AIM to Classicrocjunkie
Re: left headlight
Did you check your fuse box? a blown HDL fuse will cause them to light up, but driver side be dim. Normally thats the one to go.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2004 Pontiac Sunfire Coupe SE Getrag 5 speed
2009 Subaru Impreza WRX 5-door
www.Rdfabs.com
Classicrocjunkie is offline   Reply With Quote
Old 03-12-2008, 03:00 PM   #3
grave digger
Re: left headlight
all fuses are ok I've heard that a bad ground would cause this, but it looks like the headlight harness shares the same ground for both left and right. So I believe the bad ground theory to be wrong unless I'm wrong and their are two seperate grounds for the headlights. I'm at a complete loss here the car has only 12,000 miles on it and no warranty. I don't want to start tearing apart the harness to find a short If I don't have to. Please anymore ideas!
Old 03-19-2008, 03:45 PM   #4
91goldbomb
91goldbomb Normal reputation
Re: left headlight
i have the same problem with our 99 z24 my brother in law works at a garage and told me its a common problem with the cav and the sunfire it is a wiring problem the sockets have constant power and when the switch is turned on the ground completets the circut you have to take out the batery the washer fluid bottle and trce the wires he said the way they are designed water and slat gets up in the and messes the wires up unfortunatly this is the only thing i know
91goldbomb is offline   Reply With Quote
Bookmarks
Google
Web AF
