Me Again..chevymaniactn08 03-11-2008, 06:35 PM Ok....i Ahve Redone The Bolts On The Intake And Heads With Threadlock....will Mi Harm The Engine If I Turn The Motor Over Without It Cranking After I Drain The Oil To Make Sure All The Milky Oil Is Out? silicon212 03-11-2008, 08:50 PM Do Not Drain The Oil And Then Crank It Over. You May Damage A Bearing. Only Crank The Engine When There Is Oil In It. Chevy7x 03-14-2008, 08:46 AM if you do it by hand (pair of vicegrips on the flexplate) it shouldnt be a problem also if you have problems with getting the bad oil out pour about half a quart of tranny fluid in drive it about 50-100 miles then change oil again GreyGoose006 03-15-2008, 12:09 PM or go and buy 2 gallons of oil. fill it. turn it over and run it for a few minutes. drain oil. repeat. Automotive Network, Inc., Copyright ©2012
