Tranny Type.....
chevymaniactn08
03-11-2008, 06:32 PM
IHOW DO I KNOW WHICH ONE I HAVE?:banghead: I KNOW IT HAS A MODULATOR VALVE AND I WANTED TO ALSO KNOW DO THAT HAVE TO B HOOKED UP TO A VACUUM SOURCE FROM THE MANIFOLD OR CARB?
silicon212
03-11-2008, 08:48 PM
WHAT CAR? AND WHY ARE WE YELLING?
chevymaniactn08
03-12-2008, 09:00 AM
sorry bout that...not yelling...i sumtimes like to type in caps...its not the original tranny and engine...
silicon212
03-12-2008, 11:52 AM
Well, we're not psychic! Clue us in on some details ... pan shape, etc.
PeteA216
03-12-2008, 12:07 PM
A picture of the pan would be almost perfect for identifyting the tranny.
chevymaniactn08
03-12-2008, 01:02 PM
im thinkin its a 350 cuz it has a 13 bolt pan and the way its shape
silicon212
03-12-2008, 02:31 PM
A TH350 has no external band adjustment, has a square pan with a corner cut out at a 45 degree angle, and above the cutout at the rear, facing rear, is a vacuum modulator.
A TH250 looks the same but has a band adjustment on the passenger side behind the bellhousing.
chevymaniactn08
03-12-2008, 02:52 PM
yup its a 350....i feel really stupid right now....i appreciate u guys help for all u have helped me with....but wut i jus noticed is gonna take the cake....i had the modulator valver hose goin to the port on the carb that the vacuum advance hose pose to go to...and vice versa.....i called this guy at jeg's and he informed me that having it hooked up like that would make it idle real high and eventually bog down and backfire thru the carb....do u all agree?
silicon212
03-12-2008, 06:38 PM
It wouldn't run right, but I really don't think that would cause it to pop through the carb.
chevymaniactn08
03-12-2008, 06:43 PM
so wut should i look at about the backfiring thru the carb issue?
j cAT
03-12-2008, 07:04 PM
check compression ,,,,,,bad valve
chevymaniactn08
03-13-2008, 09:40 AM
any tips on how to check a bad valve...i know its n the head...so do i have to take the head off to see....nevermind dumb question huh?except for the first one
silicon212
03-13-2008, 12:29 PM
Please refer to the other thread you posted for symptoms of backfiring. You can check the valves by running two tests - a vacuum test followed by a compression test. A bent or burned valve will show as a rapid needle fluctuation on a vacuum test, and low compression in one cylinder will confirm that along with the cylinder #.
However, it would have to be a burned intake valve and those just don't happen.
You're more looking at ignition/cam timing or a bad camshaft.
